*Pete* Posted January 2, 2016 Posted January 2, 2016 EP91 non power steering rack Nice! Been looking for one locally for awhile with no luck, rarer not to have power steering than do. Was the rack the only thing you had to swap or the column etc as well? Quote
TimD Posted January 2, 2016 Posted January 2, 2016 Any reason why you wouldn't fit a K20? I think if I was going to all the trouble of custom mounts and what not, I'd be hard pressed to find a better engine. Quote
ToyotaTech15 Posted January 2, 2016 Author Posted January 2, 2016 Nice! Been looking for one locally for awhile with no luck, rarer not to have power steering than do. Was the rack the only thing you had to swap or the column etc as well? I just stuck up a few wanted posts and someone contacted me with one. So far it's just rack, I've not encountered an issues other that the bushes/brackets to mount to the firewall are smaller due to being a skinnier rack. Any reason why you wouldn't fit a K20?I think if I was going to all the trouble of custom mounts and what not, I'd be hard pressed to find a better engine.I haven't had much to do with the K20 and that doesn't make it a bad engine but I wanted to keep it a Toyota based conversion it's not really a huge job to make mounts, I would like to think a Honda engine would be much more of a head ache Plus I have access to everything Toyota at work which is a big plus Quote
Pikey009 Posted January 2, 2016 Posted January 2, 2016 I think it's great you're going for a Toyota based conversion and imagine the parts needed for the conversion are cheaper and like you said easier. The k20 is a fantastic engine but the 2zz is really underrated. Quote
ToyotaTech15 Posted September 7, 2017 Author Posted September 7, 2017 (edited) Realised that I haven't updated this thread in a long time!I have now reshelled the conversion to another 91 as the green one had to much corrosion,I won't blab on about it to much as I have pictures, basically all that has happened is roll cage has been done, floor has been fully repaired of all corrosion and coated and engine is duly mounted. Currently the car is being prepped for paint then it's onto the rebuild You can also follow the build on my Facebook build page https://m.facebook.com/Starlet2zzge/ Edited September 7, 2017 by ToyotaTech15 Quote
biggy_ep70 Posted September 23, 2017 Posted September 23, 2017 looks goodWonder how you gonna sort out the shaft to fit for the ep9 Quote
ToyotaTech15 Posted September 24, 2017 Author Posted September 24, 2017 looks goodWonder how you gonna sort out the shaft to fit for the ep9Thanks, Not got as far as the shafts yet, have outer and inner joints that fit but no shaft, I'll be speaking with engineering company's to come up with an option Quote
ToyotaTech15 Posted December 12, 2019 Author Posted December 12, 2019 (edited) Edited December 12, 2019 by ToyotaTech15 Quote
ToyotaTech15 Posted December 12, 2019 Author Posted December 12, 2019 Can an admin please close this thread as I have started a new one with new pictures etc Quote
