Starletsr98 Posted September 11, 2015 Posted September 11, 2015 changed the inlet manifold and now its squeeling, all pipes are connected, help will be much appreciated, 1.3 na sr Quote
StuDoc 72 Posted September 11, 2015 Posted September 11, 2015 Squeeling? Did you replace the gasket? Quote
Starletsr98 Posted September 11, 2015 Author Posted September 11, 2015 sounds like a vacum leak and no original gasket looks good Quote
5e colin Posted September 11, 2015 Posted September 11, 2015 is she revving higher ?? if so the black layer is damaged on the gasket making her squeel Quote
Starletsr98 Posted September 11, 2015 Author Posted September 11, 2015 naah it idles normal, i used brake cleaner to see if it raises revs if i find a leak and i cant find any Quote
Starletsr98 Posted September 12, 2015 Author Posted September 12, 2015 there was a crack in the inlet manifold causing it, changed the manifold and its all good Quote
