Yeah, because the engine is not a true twin cam system, the intake came is under tension. When removing the cams many forget to put the service bolt in and as such unspring the intake came.
Take the rocker cover off and turn the cam shafts till you see a hole in the cog. You should be able to see right through that hole through both cogs. If they are miss aligned you will only see through to the where the cam gear splits.
If it has been removed and not retensioned you will have to take off the intake came and retension the cams. Not a hard job at all and is a common for an amatuer to miss this.
Edited by Calum122
Sound lads Al have a look tomorrow, they bad for tappets sticking etc? Or cams warping, because car has been sound and only just started doing this noise
