Bainzey738 Posted September 13, 2015 Share Posted September 13, 2015 hi I have a 98 glanza v and there's a leak coming from where the top of the turbo oil feed pipe goes onto, how hard is this part to change what is it called? Any advice will be very apreicated thanks a lot. Luke Quote Link to post Share on other sites
daniel_g Posted September 13, 2015 Share Posted September 13, 2015 Replace with a braided oil feed and whilst youre at at change the turbo oil return pipe to a new silicon one. Quote Link to post Share on other sites
Bainzey738 Posted September 13, 2015 Author Share Posted September 13, 2015 Can I send you some pics over what's app? I'm a bit unsure wat part you mean? Quote Link to post Share on other sites
Essexglanza Posted September 15, 2015 Share Posted September 15, 2015 Put some pics up here, where the pipe meets the turbo ? Make sure the bolt is tight but don't over tighten it. I wouldn't run it for long as when that oil is hot it could catch light if hitting a hot manifold Quote Link to post Share on other sites
