Is the emanage blue and ultimate plug and play wiring harness the same??
I have blue at the moment can I just buy a Ecu unit and use the blue wiring??
Mans has anyone heard anything about the emanage gold? What's it like?
I think the ultimate had another plug on it. I think there's an adapter you con buy to wire in to go from a blue to an ultimate
I think they are the same its just an extension to your stock ecu wiring harness that allows you to splice into it without damaging the cars wiring the only thing that is specific is to 82 or 91. I could be wrong.
Is the ultimate plug and play harness different on ep91 and 82? For example I have a 91 and if I bought a set up off a 82 will it plug in and work same?
