mr_K Posted September 24, 2015 Share Posted September 24, 2015 I have a glanza with a ep82 box, The gearbox whines a lot at low revs maybe on high But cannot hear it because of exhaust sound,The gearbox also jolts back and forth and for example I'm in 3rd gear doing around 60-70miles and I let off accelerator the speed will drop rapidly like I'm braking..There is oil around the gearbox and the driveshaft inputs, I changed the seals around the box but it still leaks from there. Can the oil be because the diff is moving around a lot? Thanks Quote Link to post Share on other sites
5e colin Posted September 24, 2015 Share Posted September 24, 2015 the whine comes most from the input shaft bearing closest to the clutch if the dif is moving around alot then bearings /spacers are gone to time to rebuild the box before it seizes / self destructs Quote Link to post Share on other sites
mr_K Posted September 24, 2015 Author Share Posted September 24, 2015 the whine comes most from the input shaft bearing closest to the clutch if the dif is moving around alot then bearings /spacers are gone to time to rebuild the box before it seizes / self destructs Can the input shaft bearing be replaced?Where would you recommend me to send the gearbox off for a rebuild?In London locally I don't want to send it because they don't know how to rebuild properly.. Quote Link to post Share on other sites
5e colin Posted September 24, 2015 Share Posted September 24, 2015 yes can al be replaced in a box cant recommend anyone over there mate im in ireland maybe you have a good mechanic as friend who will do it for you ??? its not a big job for some1 in the know how 2.5 to 3 hours work to replace al the bearings Quote Link to post Share on other sites
