I have a glanza with a ep82 box,
The gearbox whines a lot at low revs maybe on high But cannot hear it because of exhaust sound,
The gearbox also jolts back and forth and for example I'm in 3rd gear doing around 60-70miles and I let off accelerator the speed will drop rapidly like I'm braking..
There is oil around the gearbox and the driveshaft inputs, I changed the seals around the box but it still leaks from there. Can the oil be because the diff is moving around a lot?
Thanks
the whine comes most from the input shaft bearing closest to the clutch
if the dif is moving around alot then bearings /spacers are gone to time to rebuild the box before it seizes / self destructs
Can the input shaft bearing be replaced?
Where would you recommend me to send the gearbox off for a rebuild?
In London locally I don't want to send it because they don't know how to rebuild properly..
yes can al be replaced in a box
cant recommend anyone over there mate im in ireland
maybe you have a good mechanic as friend who will do it for you ??? its not a big job for some1 in the know how 2.5 to 3 hours work to replace al the bearings
