Bainzey738 Posted September 24, 2015 Posted September 24, 2015 Hi need a picture of where the bolts are to take off the turbo? I've been told there 3 in the manifold and 4 on the decaf but I just can't find them, thanks. Luke Quote
patman Posted September 24, 2015 Posted September 24, 2015 (edited) there's 4 on the manifold to turbo, 4 on the turbo to decat/cat but first I would get underneath the car and take the return pipe of first with the oil feed bolt think it is, get underneath your see itAlso the water lines going to turbo too Edited September 24, 2015 by patman Quote
5e colin Posted September 24, 2015 Posted September 24, 2015 easier to undo the 6 bolts on the head to take manifold of then undo the 3 on the bottom of the cat where it meats the exhaust then 2 thet secure the cat to the cat bracket then the 19mm bango bolt on the oil filter housing so you can take out the complete unit o dont forget the open the oil return rubber pipe there is 1 bolt on the turbo to mani thats a real CUNT to open when in situ its much easier when its on the bench / floor Quote
patman Posted September 24, 2015 Posted September 24, 2015 That would be the one at the back eh Colin mate haha right pain Quote
5e colin Posted September 24, 2015 Posted September 24, 2015 ya i think thats why i went td/tf ha ha Quote
patman Posted September 24, 2015 Posted September 24, 2015 I see your point now mate though taking mani off with turbo so much easier when all off Quote
Vturbo Posted September 26, 2015 Posted September 26, 2015 Undoing the rear turbo bolts was piss easy when I did it. Just use a dogleg spanner Quote
