Paddybulldog Posted October 3, 2015 Posted October 3, 2015 Just replaced the Sony tape player with a JVC CD player and all works fine. Only issue is that it wont save stations and loses all other presets like bass/ treble etc. Anyone know why that might be? I bought the autoleads wiring harness to connect the starlet to the JVC and its all plug and play. Any help appreciated. Car is a 1997 Sportif Quote
karl. Posted October 3, 2015 Posted October 3, 2015 Look at the loom, does it give u the option to swap the red and the yellow around? If so do that and that should be you sorted. Quote
Paddybulldog Posted October 3, 2015 Author Posted October 3, 2015 Look at the loom, does it give u the option to swap the red and the yellow around? If so do that and that should be you sorted. I will have a look, thank you! Hopefully that will sort it Whilst we are at it, how do I get to the front speakers in the lower dash? The drivers one comes on and off when it feels like it, hoping its just a loose wire Quote
fordie_glanzaV Posted October 3, 2015 Posted October 3, 2015 (edited) Yeh just swap over the red and yellow connections. Is very ofter the case as 1 is perminant live and Memory needs to be to perminant live to save stations..As for the speakers just look at the panel its behind should be 4 or 5 screws looking at u undo those and whole panel will drop down. Edited October 3, 2015 by fordie_glanzaV Quote
Paddybulldog Posted October 3, 2015 Author Posted October 3, 2015 (edited) Yeh just swap over the red and yellow connections. Is very ofter the case as 1 is perminant live andMemory needs to be to perminant live to save stations..As for the speakers just look at the panel its behind should be 4 or 5 screws looking at u undo those and whole panel will drop down. Nice one, might have a look at that after work tonight! Edited October 3, 2015 by Paddybulldog Quote
