Socks Posted October 7, 2015 Posted October 7, 2015 SRF Magestic Power Plug & Play ECU EP91 Glanza V SRF Magestic Power Plug & Play ECU Rare Plug & Play ECU, connect it up, turn the key and away you go. No Remapping Required. Fuelling Check Recommended. Raised Rev Limiter to 8000rpm+ Removes 112mph/180kph Speed Limiter Removes Over Boost Protection Limiter More Aggressive Fuelling & Timing Capable of 200bhp+ on a Standard CT9 Turbocharger. Designed for Stock 4E-FTE Engines & CT9 Based Turbochargers. only £449.95 Click here to buy now! Quote
