If you get an aftermarket steering wheel, what exactly is it you need as wheel as the steering wheel? It will be a 6 bolt steering wheel by the way. Just wondering if anyone could give me a list of what I would need.
Thanks. Phil.
-Boss kit to mount the wheel on,
-airbag warning light canceller kit (if new one doesnt have an airbag)
-Horn button (unless wheel comes with one or your directing horn else where)
I think thats it, im sure someone else will be able to add to that or correct me if need be :)
Cheers I also want a quick release to I should have mentioned in the post. Would I need that as well as the boss kit or?
Thanks again. Phil.
i think you need it as a separate part if i remember, im 99% sure but would be worth just double checking :) dont know if the quick release affects the horn aswell so may need to look into that :)
Ok cheers I shall have to have a look see what is definitely need and how it can be done.
Thanks again. Phil.
I've recently purchased an aftermarket wheel (should arrive today) mine came with nothing other than the wheel itself. I have a HKB boss on its way from Japan, a few people recommended them, and it was £27 delivered from Japan. That attaches to the column and the wheel attaches to that. There is a group buy on the go ATM for a quick release, which is also quite slim, which goes between the boss and wheel and I'm sure you get the rest of it. There's plenty of videos/tutorials online to see what to do
Ok cheers. Yeah I've seen that group buy tbh I like the purple one might consider it and the steering wheel I want always it comes with the horn buttons and everything just need the boss kit and quick release. And when I finally get it all I probably will look for the tutorials. Thanks again.
Go for it! There in the lowest price bracket. Unfortunately mine doesn't even have a horn button but it was cheap so not all bad
