Oil leak between cylinder head block and exhaust manifold
Hi guys i need some help maybe someone have already passed from this problem.
I recently fitted a TD04 on my 4e engine and i noticed that there is an oil leak between the cylinder head block and the exhaust manifold.
Some people told that i could be an oil ring broken but i think it will misfire or something if an oil ring is broken. others told me that it could be the valve seals worm.
Does anyone know what the problem might be or maybe someone have already seen like this.
Thanks
i checked it, it not leaking from there for sure cause and i think if it was leaking from there the oil goes down to the timing belt
i think its more like valve seat or something like that
