Dansstarlet1996 Posted October 15, 2015 Share Posted October 15, 2015 I've only started to notice it today, but when i go into reverse with the clutch down its fine, but as i lift the clutch up the first bit it makes a grinding noise, but only for the bottom part of the pedal, when the clutch is all the way up its fine. its an 1999 NA not a glanza. has anyone had this issue or know anything about it? hoping its not the box on its way out or anything! Quote Link to post Share on other sites
