JDMfreak Posted November 7, 2015 Posted November 7, 2015 as above anyone done this ive the seal here and the seal where cup goes into box is leaking never had top do one before so any help is appreciated Quote
5T4R7ET N/A Posted November 7, 2015 Posted November 7, 2015 Once you have the drive shaft out the seal is really easy to replace, ( just pulls out)Just make sure you dont damage new seal when putting the driveshaft back in. Quote
JDMfreak Posted November 7, 2015 Author Posted November 7, 2015 Once you have the drive shaft out the seal is really easy to replace, ( just pulls out)Just make sure you dont damage new seal when putting the driveshaft back in. cheers mate wasn't sure if gearbox needed to be split as seal was inside casing or what way it was held in Quote
5T4R7ET N/A Posted November 7, 2015 Posted November 7, 2015 Just remember to drain gearbox oil before removing the Drive shafts Quote
JDMfreak Posted November 7, 2015 Author Posted November 7, 2015 24mm socket under diff housing would I be right Quote
5T4R7ET N/A Posted November 7, 2015 Posted November 7, 2015 I cant remember the size, but i know its 22-24mm. Its right at the bottom facing the passenger wheel. Quote
JDMfreak Posted November 7, 2015 Author Posted November 7, 2015 I cant remember the size, but i know its 22-24mm. Its right at the bottom facing the passenger wheel. yeah just looked spotted it there job for tomorrow Quote
