Glanzav91 Posted November 9, 2015 Posted November 9, 2015 Hi guys looking into fitting a oil catch can, anyone recommend a particular brand? Also anyone got an idea on how to fit one?. Many thanks. Quote
StuDoc 72 Posted November 9, 2015 Posted November 9, 2015 (edited) Its pretty much a non functional item so brand is completely irrelevant, just one with 2 entries and a breather will suffice. Like so http://www.ebay.co.uk/itm/BRUSHED-ALUMINIUM-OIL-BREATHER-TANK-CATCH-CAN-RESERVOIR-12mm-1-2-BLACK-FILTER-/120893790915?hash=item1c25d4dac3:g:TZoAAOSw~OdVXt5A Edited November 9, 2015 by StuDoc 72 Quote
Glanzav91 Posted November 9, 2015 Author Posted November 9, 2015 Wicked cheers stu! Does it matter if it has the breather on it? Quote
5T4R7ET N/A Posted November 9, 2015 Posted November 9, 2015 There is pressure that has to go somewhere and through the breather is the best option.So yes it should have a breather Quote
X_Milch_X Posted November 18, 2015 Posted November 18, 2015 Racework Developments: http://www.racework-developments.co.uk/index.php?main_page=product_info&cPath=7_12&products_id=3&zenid=6b1bfc1e12bd8ff57619c17c97999486 Quote
Glanzav91 Posted November 29, 2015 Author Posted November 29, 2015 So just a quick one because I've seen them set up a few ways, where do the two bits of piping that come off the catch can go into? Quote
Whitenoize Posted November 29, 2015 Posted November 29, 2015 So just a quick one because I've seen them set up a few ways, where do the two bits of piping that come off the catch can go into? onto the rocker cover mate obviously your rocker will need to be modified with an- fittings Quote
