They are non-interference, but depends if the head has been skimmed before.
Where abouts is the knocking noise coming from? I can only assume that it might well be a idler bearing/tensioner issue.
Just a update i had my mate look at it he reckoned it sound bottom endey so i droped sump off and checked crank which is nice and tight along with all other bottom end bearings, no metal deposits in the sump either
So what are my other options? bent valves?
the car will turn over and start but sound like a machine gun
before removing head, rotate crank so pistons are only half way up the bore and rotate the crankshafts and feel where there is resistance, that might give you a indication which valve could possibly be bent if you suspect its a bent valve
if you have access to cylinder leak test tool even better
first strip the cam cover side off and remove the belt and rotate the idlers and see if anything is out of place.
you should ideally take it to a mechanic- car will be in front of him and he can check while online advice only goes so far
good luck and hopes it a izi fix :thumbsup:
Cheers for the information mate
I've got a mate who is a mechanic looking at it saturdayband I've ordered valves anyway
But there isn't a garage around me I would trust lol there all robbing bastards
