Wondering if someone can help, I am going to be pulling a c52 gearbox out of a 96' 1.8 celica but wondered if the flywheel would also be the same size as the one I will need for a glanza? I am doing an auto to manual conversion so don't have an old one to measure against.
Thanks for any info
Are you using a turbo clutch kit i take it? 212mm is the turbo clutch size, the celica flywheel might be the same but you'll have to measure it.
Or just pick up a Glanza flywheel if you can find one local for a few quid :)
Thanks for that bud. I will be using a turbo clutch but was just after a rough size for the flywheel as I was told the n/a starlet flywheel is smaller.
