So I purchased a new parcel shelf as I wanted to replace the stock shelf which had some aftermarket speakers that weighed the shelf down and caused it to rattle a lot. So I picked this beauty up.
Posted Image
It's from a glanza originally and the speakers are genuine Toyota. Now! I was hoping that things would flow smoothly and all if have to do is pull back the interior trim and hope that I had the plug there waiting to connect to the new speakers and all would be good. But as we know things are never that simple... Unfortunately I don't seem to have the plug, so I'll have to wire them up the same way you would aftermarket speakers. There is wire already there from the previous install of 6x9's but I want to get fresh and replace them old wiring just for peace of mind.
Sounds simple, the only dilemma I have is this
Posted Image
I want to keep the plug as it is so I don't ruin the stock form of the shelf/wiring. So does anyone know how I could get around this or what would be easiest. There are 4 pins inside the plug, can anyone give me a little guidance?
Pop to maplins and get a box of spade connectors
Ah brilliant is that the connector that will plug into the pins then? That's pretty much all I was after so thanks :D
Is it just me or is that plug the wrong side? On my n/a and the glanza they both plug in on the drivers side?
That's exactly what I thought! I had all the plastics off on the drivers side looking for the plug as that's where everyone else's tended to be at! But I had no luck finding it, it's either not here or greatly hidden. I checked the passenger side too just in case but other than the existing wiring put in front he previous owner there was no other wires! But yeah the plug is on the passenger side of the shelf strangely
