As above will probably be attempting this tomorrow, to fit my new kit. Anyone any tips or pointers so I have an idea of what I'm getting into? lol
Thanks
Get decent circlip pliers
^^^This
I've got some pretty big circlip pliers and they work quite well but without proper circlip pliers you'll struggle, depending on mileage etc of the turbo you may need to encourage it a bit to rotate, they can be a bit stiff. I put mine in a vice and used a bar in the compressor side (where the boost pipe goes on) to spin it.
Yes the circlip is pretty big, doesn't look like it'll real easy to get out. My mate works at lorries so he has some big ones.
Does the locating pin pull out or does it need to be ground of?
