not sure about power. be good for 1.5+ bar. built by liam D. it would have to go all together. as would struggle to sell the rest of it.
if you want 300 don't go for a 20g lol. A standard 05-16g will pull 320 ish at 1.6 bar. Full boost apprx 4.6-4.8k engine spec depending.
I have a 5efte, would like bit more then 320 ;) can and 18g make it to 340 ? I have and old ebay special td05 on at the moment but think it's getting a bit tired now. So need a new turbo before remap
Get your yourself a vf/Td exhaust housing for a gt28
And a gt2871 on a 5efte would be a good setup
Phil
Gt's are expensive turbos and i have read that the vf isn't that reliable at high boost. Where as the TD seem to take quite a pounding and and not to expensive
Phil
This is a good idea. Owen Developments do a couple of concoptions like this.
What power are you looking to hit?
Whats your engine spec too? Pistons/Rods/Gasket/Cams etc? All makes a lot of difference.
Unsure of specs but forged 5e engine 1.2mm headgasket and I belive standard head, looking for 340 as I should be able to hit that with no headwork and keeping standard inlet.
