sosolid Posted December 9, 2015 Posted December 9, 2015 Isit better to just change the bushes of the OEM panhard rod bushes to poly rather than changing the whole rod to a Whiteline one? Quote
Ollieh17 Posted December 9, 2015 Posted December 9, 2015 (edited) If your car is lowered better to change to a adjustable one Edited December 9, 2015 by Ollieh17 Quote
sosolid Posted December 9, 2015 Author Posted December 9, 2015 Yeah its lowered on teins. So if I was to change it to an adjustable one what length would I adjust it too? Its on Teins springs and KYB gas shocks so its not touching the ground lol Quote
5T4R7ET N/A Posted December 9, 2015 Posted December 9, 2015 You need to take it to a alignment garage. They will sort it out for you. Bit like tracking, very difficult to do it your self unless you have eqiupment Quote
Ollieh17 Posted December 9, 2015 Posted December 9, 2015 Ive always done it by eye and never had an issue Quote
5T4R7ET N/A Posted December 9, 2015 Posted December 9, 2015 Only real way of telling you got it right is by having it checked afterwards. Quote
Di_Bodi Posted December 18, 2015 Posted December 18, 2015 Is it the driver's side (RHS) rear wheel being pushed out lads or the passenger side (after lowering)? In my case it's the driver's side where the arch is rubbing the wheel... Quote
StuDoc 72 Posted December 18, 2015 Posted December 18, 2015 sure it pushes out the passenger side wheel if my memory serves me right when I fitted mine. If your drivers side wheel is buffing the arch you most likely need to lengthen your bar slightly. Quote
Di_Bodi Posted December 18, 2015 Posted December 18, 2015 (edited) When I look at the whole set up (photo below) it makes sense what you're saying StyDoc 72 - the axle should go left after lowering as the fixed point is at the rhs!Why my one is such a stubborn one and went the opposite way...Hmmm..I had the alignment checked and there is minimally more of camber at the RHS wheel so maybe I should swap them shocks around (absorber's stud might be slighly bent?) and check how it's all fixed then! I know - she's dirty:)) but it was really ugly day! Edited December 18, 2015 by Di_Bodi Quote
