My gt has started crunching into gear, but only when I'm changing quickly when driving hard, or if I change from 3rd straight to 5th without pausing in neutral.
The clutch does have a bit of release bearing rattle and the gear change is very choppy but under normal driving it's fine. The rattle does take a second to go away after you've pressed the clutch down.
My plan is to bleed the clutch,change the box oil and I've got some of those bearings to replace the linkage bushes.
You guys reckon this will solve my issues?
Or has anyone had the same issues and know what it is?
Car isn't a daily atm, been working on the daily too much and neglecting the gt
My clutch did the same for about a month and wouldn't let me down shift into 2nd and one day driving to my mums all the springs in the pressure plate just let go and I had no drive
Mine used to do this until the box was warm, I never found the issue out just made sure the gearbox was nice and warm before any hard driving.
I was told to put a thicker oil in but that surly just masks the issue, could be synchros ?
