Has anyone used a cheaper version of a 255lph fuel pump other than walbro seen a 255lph APS one on eBay for 60 quid was wondering anyone have any experience with cheaper 255 pumps and do they burn out or give trouble thanks in advance for any replies lads :)
I've purchased the APS one so will see how it goes I couldn't find any quantum ones for a starlet :/ has anyone any experience with APS pumps, fuel pressure will only be at 3.1 bar for a bar boost pressure so won't be running crazy boost or fuel
Also is it completely necessary to run a rising rate fuel pressure regulator with a 255 pump and standard injectors on a bar boost running td04? I've read a few times that the standard regulator will cope quite happily unless your running a larger fuel system with bigger lines
