ChrisLeeBoost Posted December 26, 2015 Posted December 26, 2015 Hi lads I'm in the process of fitting bits to get the Glanza mapped, I've an emanage but no harness and I've purchased a plug and play harness off a lad but I recently realised its just air and fuel control in the harness and he said he can add the ignition harness in for extra cost but do I need the ignition harness I'm presuming I do before I buy it just thought I'd get some help with it thanks lads Quote
ChrisLeeBoost Posted December 27, 2015 Author Posted December 27, 2015 Just seen a zisco extension harness for the ep91 it has three plugs on it but the ecu has 2 ? The ep82 extension harness has 2 plugs on it so I'm a bit confused is the ecu that I have made for ep82s or which one should I have? Quote
akyakapotter Posted December 27, 2015 Posted December 27, 2015 (edited) You will have the harness thats came with the emb which will be igniton and fuel harness to be hard wired into the stock ecu wiring.The zisco one will be a field harness so you dont have to wire it to the stock ecu wiring it will go to that or if its a plug and play harness no wiring at all imo they are a waste of time when are you ever going to remove the ecu after its mapped ?cheers nick. http://www.boomslang.us/e-manage-blue.php thats a proper plug and play harness zisco one is like a said a harness to wire your 2 harnesse to http://www.ziscoperformance.co.uk/index.php?main_page=product_info&cPath=11&products_id=36 Edited December 27, 2015 by akyakapotter Quote
ChrisLeeBoost Posted December 27, 2015 Author Posted December 27, 2015 That one on boomslang looks the job, will make things a lot easier if I ever break the car for parts it'll be removed and make it easier to remove Quote
ChrisLeeBoost Posted December 30, 2015 Author Posted December 30, 2015 Does the emb remove speed limit or can it be mapped to remove speed limit? Quote
akyakapotter Posted December 30, 2015 Posted December 30, 2015 No the Emb dosent remove speed cut you have to convert the speedo to mph Quote
ChrisLeeBoost Posted December 31, 2015 Author Posted December 31, 2015 How do I go about this mate thanks Quote
akyakapotter Posted December 31, 2015 Posted December 31, 2015 With mine I have a converter that goes into the top of the gearbox changes from kph to mph Quote
ChrisLeeBoost Posted January 1, 2016 Author Posted January 1, 2016 Have you got any links for these mate sounds ideal less messing around than installing SLD Quote
