Justforfun Posted January 6, 2016 Share Posted January 6, 2016 (edited) I'm going to fit one in to the car next week I'm ok with fitting it I'm just nervous about setting the pressure properly. Is this something I can really do myself or am I better off having someone do it? Watched the step by step guide on gtt Edited January 6, 2016 by Justforfun Quote Link to post Share on other sites
patman Posted January 6, 2016 Share Posted January 6, 2016 Haven't seen the step by step guide on gtt I have one fitted but have a wideband aswell first things first are you running a fuel cut defender? What boost are you putting it too etc Quote Link to post Share on other sites
Justforfun Posted January 6, 2016 Author Share Posted January 6, 2016 On 1/6/2016 at 9:24 PM, patman said: Haven't seen the step by step guide on gtt I have one fitted but have a wideband aswell first things first are you running a fuel cut defender? What boost are you putting it too etcyeah I have a fcd in it. I'm just after buying a Speedvision hybrid gen 3 also a walbro fuel pump now this fpr. I'm going to run it at .9 I'm going to do the 3 things all at once next week. Quote Link to post Share on other sites
patman Posted January 6, 2016 Share Posted January 6, 2016 (edited) Is a hks one? If so what setting is it on at the moment Edited January 6, 2016 by patman Quote Link to post Share on other sites
Justforfun Posted January 6, 2016 Author Share Posted January 6, 2016 On 1/6/2016 at 9:59 PM, patman said: Is a hks one? If so what setting is it on at the momentNo its just a universal one for now. Quote Link to post Share on other sites
patman Posted January 6, 2016 Share Posted January 6, 2016 I'm sure everyone will agree here mate get everything fitted and crawl (no boost) to a rolling road and get it set up right that's your best bet Quote Link to post Share on other sites
Justforfun Posted January 6, 2016 Author Share Posted January 6, 2016 On 1/6/2016 at 10:22 PM, patman said: I'm sure everyone will agree here mate get everything fitted and crawl (no boost) to a rolling road and get it set up right that's your best bet Cheers man. Quote Link to post Share on other sites
Justforfun Posted January 6, 2016 Author Share Posted January 6, 2016 On 1/6/2016 at 10:22 PM, patman said: I'm sure everyone will agree here mate get everything fitted and crawl (no boost) to a rolling road and get it set up right that's your best betI should have mentioned I'm already boosting at .9 so I won't be going near the boost if that makes any difference. Quote Link to post Share on other sites
patman Posted January 6, 2016 Share Posted January 6, 2016 It's not so much what your boosting at mate it's knowing if your running lean on boost etc so a rolling road would be a good way to see, seing as you haven't got a wideband fitted in Quote Link to post Share on other sites
5e colin Posted January 6, 2016 Share Posted January 6, 2016 set the fp to 3bar for 1 bar ct9 when engine is hot and take of the vacuum hose ( block the vacuum hose to ) Quote Link to post Share on other sites
Justforfun Posted January 6, 2016 Author Share Posted January 6, 2016 Cheers for the replys lads. Quote Link to post Share on other sites
