Hi,
I've had a search through and not found anything, does anyone know a good source (ideally OE) for outer CV boots, every single one I've had off the motor factors / off eBay has always been slightly too big.
Cheers
Outer is universal really. Have big universal ones on mine and they are perfect. Just once there is grease in there and the cv is protected from the elements it's all good. Whereas the inner cv that goes into the cup needs a proper boot as the cup has grooves that a universal boot doesn't have so they don't fit properly but if you're not fussy the universal boot will do fine on the inner also.
