just sorted my wepr ramhorn manifold setup but struggling to find a good place to locate my air filter
as the new manifold sit at a 45 degree angle from block
i was running the standard relocation kit but this now faces in 45 degrees is there a better way ? space i tight i tryed using only one 90 silicone bend but that wont fit if anyone has any pics of their set up might help
thanks
Just cut a 45 degree off the turbo side of your silicon relocation kit. Thus counteracting the additional 45 from the turbo kit allowing you to keep the relocation kit in its original place
yeah half rad and air con removed
was thinking of either buying a 45 degree pipe or a small straight piece just didnt know if anyone had any pics of what theyd done would be handy
