abs light on since i got car running
but i cant stand over any of sensors as they were all on the car
pinned out tc and e1
99% sure i got 31, 32, 33 and 34 all abs sensor malfunctions at each wheel
also got 41 battery voltage high or low
tried reseting via pumping brakes also i dont have ecu b fuse to pull
bit odd that all sensors would come up bad and have seen on occasions people have had abs issues over low voltage
im wondering if mine is high voltage as im using the spare battery out of my daily 2litre petrol accord?
any help appreciated
need to double check codes as there very hard to see blinking
  • 2 weeks later...
i think its the connectors mate as your car was stripped to the bone the plugs are in the engine bay and near the back seat make sure there fine use a multimeter to test the sensors and check the remaining cablet to abs ecu for continuity/ cracks / damage
thats the first thing to look at
What reading should I get back from sensors with multimeter? My gut says broken wire causing the sensors to not get power or something like that...
1 loom runs Down the drivers wing an then the other across the front of the bay into the fuse box ? Any where else worth looking
Unplug the sensors.
Put multimeter on the 2 prongs
Spin the wheel.
If you get a reading the sensor is fine.
If you dont then its fucked.
Simples :thumbsup:
That's handy to know. Never been told that.
John
  • 2 weeks later...
