Over boost 2nd gear bog fuel cut help
just wondering someone could give me some advice! Could you launch your glanza in second gear? Totally stuck, bypassed the solenoid ages ago and running fine and boosting not long got a front mount, decat, hks filter, Greddy gauge to monitor it all tonight first time ever I've been trying starts in second just wouldn't have it bogging down on 4k and even below, so checked gauge and hit fuel cut once by the looks of it atleast as was on 0.85 last reading but I was on about 3k a few times and dying so I put the high low boost back to standard with fly in first just like bypassed but still no 2nd gear launch with it bypassed and can't be hitting fuel cut even if it's cold outside and condensing ,will they not take off nicely in second gear and just use first and problem solved? Any help would be great Thanks Gonna run the standard boost on solenoid as too scared fuel cut is going to damage it! Been told to run solenoid in winter and put it back to bypassed in summer and porting the turbo and adjustable acuator will make it more stable? But second gear start has me stumped! Thanks guys pretty new to the scene
