Well lads gave the car a bit of a send on in 2nd earlier on and it banged and engine light popped on for literally a split second when it banged but car ran fine after it could it have been fuel cut or what? It's external gate on .7 boost standard ecu and injectors
yup to much boost and ecu conked her out kid ut to high on the boost on stock ecu and injectors ( 0.5max !!! )
ecu will have seen lean condition on the sensor and an cut
i bet if you do a diagnostic test you will get code 25 contineus ( lean ) condition
turn her back down before u blow your 4efte kid
