Basically I have oil being sprayed out my DV when changing gear on boost!
If I just potter about off boost its fine!
Does this sound like the turbo oil seals ?
Or could it be because the oil is slightly overfilled ? as I had to top it up as I had a bad leak from the cam cover! It's sitting on the F mark when engine is cold.
If oil is overfilled it won't come out of the intake, it'll go down the breather setup and up past the rings. Sounds more like turbo to me, still a CT9?
Just checking as wanted to rule out everything else before I take the turbo off!
Yeah still Ct9
