Lads that are in the know,
I have the above brake setup on my car for a while now, but can't for the life of me find the exact disks and pads I need to buy for replacements, I'm looking into a set of red stuff with a set of grooved disks.
Anyone with any knowledge on the area would be much appreciated!
Picture:
Edited by CTopZ
Pretty sure they are the same as MR2 turbo twinpots which are the same as levin pads.
As for discs i dont know of many people using that exact setup but if its anything like the levin setup which id say it is. Its fairly common to use 1.7 astra discs with a spigot ring (think i can see them in the pic) and they are usually machined down to 260mm as they come as 277mm
I think you can use 99-02 mr2 front discs i read somewhere recently
stock astra discs come 280mm and need to be machined down as stated
mk1 mr2 discs will fit but are the same as corolla discs which are quite a substancial amount thinner than astra discs and not really an upgrade to stock starlet discs
just a heads up I know exactly what setup you have there if you require any info or parts feel free to drop me a pm
Edited by russ78
