EP70-PT Posted February 21, 2016 Posted February 21, 2016 My 4th lead pops and when I try to put it back there's a lot of resistance (vaccum) time for NGK leads and new plugs?? Quote
5e colin Posted February 21, 2016 Posted February 21, 2016 could try that indeed but for it popping out your rocker cover to sparkplug bore seal might be the isseu back pressure blowing it out ??? is it oily ?? Quote
5e colin Posted February 21, 2016 Posted February 21, 2016 would change those 4 sparkplug seal then to Quote
EP70-PT Posted February 21, 2016 Author Posted February 21, 2016 Is it the little ring that goes around the plug ? Quote
5e colin Posted February 21, 2016 Posted February 21, 2016 you see them when you unbolt the rocker cover and flip over the cover you will see the 4 seals around the holes where sparkys go very easy to instal just make sure seal ir right way up or down wich ever way your looking at it do 1 at the time so you see wich it top and bottom Quote
