Hi All,
Looking into the above it looks like most that have a catch can block off the PCV valve from the inlet mani does anyone have a link for the block pipe?
What do people do when having catch cans but don't have the fittings in the rocker cover? Where the pcv valve goes do they just take the pcv valve out and just have a pipe running down that hole to the catch can?
I gutted the pcv valve and put a pipe from it to the catch and from the other pipe on rocker to catch can and blocked off the inlet mani ,getting the fittings put on the weekend doh far tidier looking :)
What did you use to block it off?
I took it out and cut the bottom off so it let the spring and ball fall out stuck it back in and put the hoses on :) I just used a silicone blanking cap for the inlet manifold
  • 1 month later...
