X_Milch_X Posted February 21, 2016 Share Posted February 21, 2016 Hi All, Looking into the above it looks like most that have a catch can block off the PCV valve from the inlet mani does anyone have a link for the block pipe? Quote Link to post Share on other sites
Cattanach Posted February 22, 2016 Share Posted February 22, 2016 Blocking the nipple on the inlet mani ? Quote Link to post Share on other sites
patman Posted February 22, 2016 Share Posted February 22, 2016 What do people do when having catch cans but don't have the fittings in the rocker cover? Where the pcv valve goes do they just take the pcv valve out and just have a pipe running down that hole to the catch can? Quote Link to post Share on other sites
Bug679 Posted February 22, 2016 Share Posted February 22, 2016 I gutted the pcv valve and put a pipe from it to the catch and from the other pipe on rocker to catch can and blocked off the inlet mani ,getting the fittings put on the weekend doh far tidier looking Quote Link to post Share on other sites
patman Posted February 22, 2016 Share Posted February 22, 2016 Thanks for the message bug mate did you actually take out the pcv valve grommet or just leave that in? Quote Link to post Share on other sites
X_Milch_X Posted February 22, 2016 Author Share Posted February 22, 2016 On 2/22/2016 at 9:29 PM, Bug679 said: I gutted the pcv valve and put a pipe from it to the catch and from the other pipe on rocker to catch can and blocked off the inlet mani ,getting the fittings put on the weekend doh far tidier looking What did you use to block it off? Quote Link to post Share on other sites
Bug679 Posted February 23, 2016 Share Posted February 23, 2016 I took it out and cut the bottom off so it let the spring and ball fall out stuck it back in and put the hoses on I just used a silicone blanking cap for the inlet manifold Quote Link to post Share on other sites
patman Posted February 23, 2016 Share Posted February 23, 2016 Thanks mate 👍🏻 Quote Link to post Share on other sites
X_Milch_X Posted February 23, 2016 Author Share Posted February 23, 2016 Top man don't suppose you know what size fitted the inlet mani for the silicone blanking cap? Quote Link to post Share on other sites
patman Posted February 23, 2016 Share Posted February 23, 2016 I've seen some people just put a bolt in the pipe to block it off. Quote Link to post Share on other sites
Bug679 Posted February 23, 2016 Share Posted February 23, 2016 Bit a hose and bolt work to used it at the start Think it's 10mm for the inlet Quote Link to post Share on other sites
Bug679 Posted February 23, 2016 Share Posted February 23, 2016 Just make sure your catch can has a breather before ya gut PCv or it'll smoke like fuck Quote Link to post Share on other sites
patman Posted February 23, 2016 Share Posted February 23, 2016 Yeah that's true mate I have got a catch can here at home but no breather hence why that didn't go on. Quote Link to post Share on other sites
X_Milch_X Posted March 23, 2016 Author Share Posted March 23, 2016 Thanks to all above all setup now Quote Link to post Share on other sites
Bug679 Posted March 24, 2016 Share Posted March 24, 2016 That looks the business now mate 👍🏻 what catch can you have ? Quote Link to post Share on other sites
gorganl2000 Posted March 24, 2016 Share Posted March 24, 2016 honestly that looks quite tidy Quote Link to post Share on other sites
X_Milch_X Posted March 24, 2016 Author Share Posted March 24, 2016 On 3/24/2016 at 1:42 PM, Bug679 said: That looks the business now mate what catch can you have ? Race Works On 3/24/2016 at 6:10 PM, gorganl2000 said: honestly that looks quite tidy Thanks buddy Quote Link to post Share on other sites
