How's everyone?
Been a while since I've been on the forum but having trouble and need some help!
Not sure if this is in the right section so sorry if it isn't.
Long story short,I fully forged a 5e,got a big turbo kit,cams and spec'd the head to suit and got it running.
Starts fine and idles perfect when cold but once it heats up it sits down around 400rpm and cuts out if it feels like it.
I've replaced the coolant temperature sensor,checked for vacuum leaks and no joy.Adjusting the screw on the throttle body makes no difference whether it's screwed all the way in or out.
I took out the plugs today and they were black and soaked in petrol.
It's running standard injectors,has an uprated fuel pump and is running 2.6 bar fuel pressure because that's the way it was set up by the lad who built it.
I haven't been driving the car,it's done no miles but has been running periodically so it's only got a few hours on it.
Any suggestions as to what might solve the problem?
  • 3 weeks later...
