dj-rix Posted March 1, 2016 Posted March 1, 2016 Some idiot fitted an FCD right next to the Ecu and removed it leaving the wires in a mess, blobs of solder and electrical tape. Any way to test that the wires are ok and not giving a dodgy signal/ voltage to the map sensor? Quote
patman Posted March 1, 2016 Posted March 1, 2016 I'm guessing it's the green wire mate? Well is on my GT, I have got it sorted as took my fcd off idiot before done a crap job too Quote
Stu Posted March 1, 2016 Posted March 1, 2016 There's three wires to a map sensor - stable 5v feed (VCC), signal ground (E2 or E21 pin usually depending on which series ecu) and the map signal back to the ecu (PIM). Quote
