Colin1989 Posted March 5, 2016 Share Posted March 5, 2016 Anyone know which intercoolers fit without cutting the front bumper? I will be removing the aircon. Any info would be helpful.Thanks Colin. Quote Link to post Share on other sites
chriswep91 Posted March 5, 2016 Share Posted March 5, 2016 I'd like to know too Quote Link to post Share on other sites
jamesglanza Posted March 6, 2016 Share Posted March 6, 2016 Anything with a core size of 450mm (700mm Inc end tanks) x 270mm and around 50-70mm thick. It's mainly the pipework that will faul the bumper and requires trimming. If the core is mounted close to or behind the crash bar with air con rad then it's doable if your running ct9 with 2" pipework. If your not running air con rad then a rear entry intercooler core and some custom or short route pipework in 2.5" could see you well away from the bumper. Check out the WEPR kits, Sacha used to do a ct9 kit with a 2" core and 2" pipework that fitted really tight on stock set up with very minor trimming to the bumper. Also the rear entry kits. I'm sure there is others on the market Hope that helps. Quote Link to post Share on other sites
gorganl2000 Posted March 7, 2016 Share Posted March 7, 2016 Anyone know which intercoolers fit without cutting the front bumper? I will be removing the aircon. Any info would be helpful.Thanks Colin. http://www.toyotagtturbo.com/forums/showthread.php?20735-FMIC-comparisons-King-thread tons of info and pics Quote Link to post Share on other sites
