nano
    126
    reunion
3385 profile views
nano's Achievements
  1. hi, still available?
  2. Thanks is it possible to get the ring , i have the disc with no.ring and no abs.
  3. Hello, Who has ever mounted a speed sensor to the rear of a Starlet? What type of sensors to choose and where it should be mounted? Is it a quite easy operation? This is for setting launch control based on rpm and ground speed. Thanks
  4. Alright mate thanks a lot
  5. Thanks rob. Could you specify a model please, single, double clutch?
  6. Hi, i installed greddy ultimate piggyback with boomslang harness about a year ago, it was ok. My oem ecu loom was a mess so i decided to make a more tidy one. The problem is now the car wont start. It smells fuel. Remove the emu. Oem ecu plugged only. Car runs fine. I think the emu is faulty. Is it possible To use emu without using ignition input output if i just loop them? Thanks
  7. Hi the hose to bov is ok. Very easy to see if there is a leak there. Thanks
  8. Hi everybody, I was driving my car on full boost ,0.8bar. Suddenly i heard like bang, car lost power and wont boost over 0.2bar.Car is running good under boost though, no smoke no rattle etc... I checked ic piping, all good. Dump valve is ok too. The wastegate is a genuine tial f38 i bought 6 years ago. Can a bad diaphragm cause boost leak or on the contrary i should overboost as the valve wont open. I m confused because my friend says a bad Diaphragm can cause boost leak. Can it be the turbo itself? I say again no whislte no smoke at exhaust.
  9. Hi do u still have target AFR map for e manage? id like to have a look. email to machelinniss@hotmail.com thanks
    1. nano
      nano
      Hi, what do toi mean? You want To see my map ? Where did u rend i ve this?
  10. Ok sorted. Injectors harness is not good. I used my 2ee one and injectors are all together and in a 4efte they re seperate
  11. Hi, my car is running really bad atm. It starts well. But idle is rich(Black plugs) and 10afr on brand new aem wideband and cant accelerate smoothly. In one Word its undrivable. My attention is on the map sensor. I get 1.7v on idle with multimètre on pim line when its idling and 2.66v ignition on engine off Shouldnt it be around 0.2v when idling ? Can someone confirm this please. If so, mean map sensor needs to be replaced?
  12. Thanks. One more question : i ve distributor ox and knock loom all together and its added to the main loom. They are all shield and they end in a Orange connector where ground wires but they are cut. Can i ground the shielding on the châssis ? What happens if the shielding arent grounded? Is it something to worry about or no importance ?thanks
  13. nano
    ep91 4efe to 4efte
    Hi I m adding o2 distributor and knock sensor loom for a gt conversion. All the shieldings go To a connector with brown wires but they are cut. Must i connect thoses Hi I m adding o2 distributor and knock sensor loom for a gt conversion. All the shieldings go To a connector with brown wires but they are cut. Must i connect one brown wire to the main loom? Can i leave it like that? What causes not to earth them? Thanks
  14. Ok sorted 60amp yellow fuse was dead. I think this is for alternator.
