slo7899
    54
About slo7899
  • Birthday 10/18/1990
    Yorkshire
2184 profile views
slo7899's Achievements
  1. Anyone going?
  2. Removed mine because it didn't work anyway. Would of probably cost more to fix then to get a abs delete. Plus if u have it and it doesn't work come mot time then it's a fail.
  3. Yea I have WMS and they don't fill me with confidence anymore. Booked on at Cadwell on the 8th of Dec aswell.
  4. Hi all. Has anyone who fitted a abs delete kit had a spongy break pedal after bleeding. No matter how many times I bleed my callers I can never seem to get them to feel right. The travel on the pedal is rather concerning aswell. Anyone have any experience to share. I was thinking maby the master cylinder itself might be fubar or that the master cylinder need bleeding on its own. Cheers.
  5. How did the day go?
  6. Anyone have the part number. Cheers.
  7. Hi all. Does anyone know where I can these from, as mine a in abit of a sorry state.
  8. Awesome, thanks mate.
  9. I suppose there’s only one way to find out :) Nothing fancy on the future plans side of things, (he says) would probably be a forged bottom end build keeping the same turbo setup. And getting this screamer pipe plumbed back into the exhaust for track days. I wouldn’t mind giving you the car Rob, so you could work your magic on a wire tuck. Looks very impressive.
  10. Cheers for the replys guys. Will at RDT mapped it mate, he did a great job. I’ve not long just spoke to Will about it and he says that it shouldn’t be a problem ;) I’ve ordered the one from M.E. Along with 3 bar map sensor and some 800cc injectors (bit overkill), so hopefully that will do the trick for the next mapping session.
  11. Hi all. Im currently running a hybrid td04 EWG setup on standard internals. Currently mapped on the ME221 using wastegate spring pressure. I am wondering could I use a 3 port boost control solenoid instead of using a EBC. Cheers, Chris.
  12. Cheers for the reply. I have the ME221
  13. Hi all. Would these injectors fit my glanza. Running TDO4 hybrid on standard internals. Maby abit overkill but good if I want to go further with upgrades in the future. https://www.ebay.co.uk/i/122377688252 What at you guys think??? Cheers, Chris.
  14. Are they a direct fit?
  15. Currently on ME221 with TD04 hybrid on stock internals for now. 400-500cc should be ok I think. Correct me if I'm wrong. Cheers.
