mccartney11 Posted May 31, 2017 Share Posted May 31, 2017 First time dealing with turbo Toyota setup , I've converted my ep70 to 5efte, when I start it it cuts out 3-4 time then it'll start and run at 700rpm sounds like it's running on 2 cylinders and won't rev properly, but as it warms up it revs normal, any ideas?Next is it gets hot quite quickly, like after 4-5 mins running the heat off the manifold is severe , making me wonder is something up I've never known them to get this hot, it's also boiling the water in the rad , it's blowing steam out the overflow , both rad pipes are hot , I've checked thermostat and it's opening and closing fine, any other things to try before I put it down to head gasket? Any help appreciated as I'm new to turbo set ups only used to dealing with 1e& 2e's in starlets Quote Link to post Share on other sites
mccartney11 Posted June 2, 2017 Author Share Posted June 2, 2017 Bump Quote Link to post Share on other sites
Chops Posted June 3, 2017 Share Posted June 3, 2017 Timing? Recently one of mine ran like a bag of shit till i sorted its timing out. Coolant sounds like hg or water pump failure Quote Link to post Share on other sites
mccartney11 Posted June 3, 2017 Author Share Posted June 3, 2017 I don't see how it runs ok while it's a bit warmed up ? Quote Link to post Share on other sites
Chops Posted June 4, 2017 Share Posted June 4, 2017 Id still say it sounds ignition ey. The coolant coulx be a blocked rad too, how old is it? Quote Link to post Share on other sites
mccartney11 Posted June 4, 2017 Author Share Posted June 4, 2017 Sorted hearing issue was the rad cap Quote Link to post Share on other sites
