What size diameter is the outside of td04 air intake?
Looking for a silicone elbow to fit on the air intake of td04 to fit my air filter what size diameter hose would I need to fit the intake properly have seen a few different answers, cheers
This might sound crazy.. but have you thought about measuring it yourself?
You aren't measuring bearing clearances, just use a ruler, or tape measure to give you an idea and order something as close as you can find.
Can only find a 57mm unfortunately hoping that should be ok with real tight clamps etc, what you reckon? Going 57mm-76mm silicone 90 from turbo then 76mm alloy 90 to a small 76-83mm hose joiner to filter only way can do it with this apexi filter really
