Levin twin pot hubs
6 posts in this topic
I am not sure if this has been posted before, however I’m getting a set of twin pot calipers together with the hub. Does the hub bolt on to the Ep82 or are there some mods needed?
Share this post
Ya for sure the strut holes don't line up I remember that long ago on 1 of my budget diy coilys  if the driveshaft slots in then your I. Luck  it be a simple install
Don't forget the endface distance on the backside of the hub shaft might be shorter ???? Or not
Share this post
Ae111 Levin hubs that come with twinpots won't fit as theyre from the super strut model which is a completely different suspension setup to the mcpherson used on starlets.
The top of the hub is mounted to the shock with a ball joint and the lower mount is 2 balljoints to connect to 2 separate wishbone arms
Share this post
All ae111 SSS are twinpot yes, not sure on the ae101s. If you fit them to the non SS (mcpherson) hubs you end up with 260mm brakes. But if you use celica caliper carriers on the mcpherson hubs you can space them out to be 275mm like the SSS setup.
The mcpherson hubs are the same as uk corollas.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
