24 -
About jack_wetone
- Birthday 03/22/1996
hampshire
jack_wetone's Achievements
i know there are different sensors in different years yes when i changed my sr engine to 5e there was a difference in sensors and there was an extra 1 to i dont know if thats any help
What is the uk spec 4efe stArlet gearbox
jack_wetone replied to jack_wetone's topic in Drivetrain & Transmission
yer it pulls nice got loads more torque and got a nice 100hp corolla 4-2-1 exhaust manifold and inlet to fit also so should finish the change off nicely -
yes that was me although there wasn't really anything wrong as such just wined a bit on tick over couldn't hear it once moving I'm only wondering cas I have since put a 5efe engine and box in and i just wondered wich one would be better in my car, I'm not gona put the old one back in but there's another 1 with low milage in my yard and wondered if it's worth getting before it's scrapped to go in mine otherwise I won't bother thanks -
okay well what I really won't to know is are the paseo boxes the same I have both boxes and have seen and been told that they are different ratios according to wiki paseo is the c150 box and at dosent say wich one is the starlet box so ? -
okay so someone put me outa my misery what gearboxes do the uk spec ep91s have in them ? Thanks
hi thanks for the info very handy did u get it to run? i have the inlet manifold an tb from the same car so i have the right sensors to go with it, could u give me a bit more info on what wires u joined together just im not quite sure witch ones u joined ?thanks
Peace of piss I done mine in half a day on my own did have a fork lift tho which is rather handy 😉
Did u sort this prob ?
i have searched and searched i have a starlet sr ep91 with 5efe engine on standard ecu i want to try and put this ecu in that i got when i was getting a 4-2-1 exhaust mani and intake manifold and tb i beleive same as turbo and yellow/brown injectors from a ee101 4efe corolla that had no imobiliser or from what i could see it didnt it was a k reg 92 any ideas if this will work or if i can make it work and what does the green label mean ? it is quite a bit bigger my starlet ecu is 2/3 the size of the corolla one. any help apriciated thanks
sr spring needed where can i get one or who has one ?
jack_wetone replied to jack_wetone's topic in Chassis & Suspension
brought a full set after market 35mm from euro car parts £115 sorted ! -
best 4/5e genuine inlet mani help
jack_wetone replied to jack_wetone's topic in Intake, Turbo & Exhaust
right okay well im putting a 5efhe in from a sera witch i believe does not have acis manifold so i will be getting a corolla 1 do the acis manifold require any additional wiring ? thanks also what cars have the acis manifolds on? -
sorry if i have opened something that has been covered but after trawling the internet i cannot find anything so, i want to know what the best inlet is for the 4/5 n/a(naturally aspirated) e series engine is im guessing the acis is best but we all know how hard they are to find so, and everyone says that the corolla tubular one is the best but then i have also seen people saying 5efhe is best and the turbo inlet is best ? what i'm asking is i suppose is the corolla the 2 best or is the 5efhe (sera) one second best? 1st best being acis(Acoustic Control Induction System) manifold ? thanks
okay well i got a lot to think about and a lot of spare time soon to as im loosing my license and so im doing a 5efe conversion i am thinking of fitting the hole lot as in engine and gear box in 1 go will this work ? is it better with paseo box or is it same as starlet ? and also wana fit the 5efe ecu im not gona reprogram i was just thinking of swoping the hole lot as in ecu chip reader and barrel any one done this ? as for the 5efe it has done 140k and burns oil so im gona rebuild it, i was just going to put a set of valve stem oil seals and rings in there but whilst im in there are there anymods i can do i want just toyota parts not aftermarket (budget build) i know about 5efhe cams but what about pistons what e series engine has the best pistons as such and can i fit them and what about heads is there a best head ? that allows the best flow or am i better off port and polishing? i am aslo gona do the obvious and put corolla manifold inlet and outlet 4branch in and 4-2-1 out and make/buy exhaust system any advice on any of the that would be great thanks oh and a 6 speed if i can get one! cheap enough!!
