McGeary1
    89
    Kent
1387 profile views
McGeary1's Achievements
  1. Did you solve your problem? I have no fuel pump until I connect a live from the inside fuse box 😟 sounds like the same issue I have
  2. Thanks enots, no I haven't tryed that but the wiring is still all connected, I've just spliced into the pumps live (blue and white) with a wire from the inside fuse box. Very redneck but had to get it working Also which pins?
  3. As above. It's a walbro one, the actual pump is working but I've had to steal a live from inside the car and run it direct to the pump. Problem now is as soon as I turn the key the pump kicks in and the won't start the car. What could be the problem?
  4. I'm in need of new exhaust bolts or studs. Not sure what the oem bolts are from the manifold to turbo and from decat pipe to exhaust system. I just had a random selection holding it together and want the right size this time. Thanks guys hi5
  5. How can you tell if the ecu is knackered?
  6. This bloke is top class and the most patient seller EVER, a credit to the starlet/Glanza life. Hope td do you well mate with the forged 👍 and we'll have a beer at japfest next year ✋ on me. Hope to do quicker business next time 😂
  7. M9
  8. Brilliant bud. I've pm'd you as well.
  9. hi, is this still for sale?
  10. McGeary1
    Engine time.
    Next couple of months I'm going to need a new engine. Is there any where that stock them? any where I should not use? Is any one braking one soon with low mileage? I need a good low mileage engine with compression test results would be nice. Or Has Anyone brough a forged stage 2 from td and put it in themselfs Thanks for any help like I said I'm on the hunt and save for a really good clean engine now
  11. The gasket fits the other two heads I have, it's what I thought was the only gasket. As you look at the inlet manifold on the right hand side at the bottom where is a big part and on my head that has a water jacket going to the inlet manifold, there is also a square hole which is particially coverd by the gasket
  12. I can't show pictures 😭 I don't have photobucket
  13. As above, the new (to me) ep91 head I got has an extra water out to the inlet manifold, do I need a different gasket or inlet manifold? I'm confused by this 😩
  14. Don't see many of them for sale 😳
  15. What's the other option, get a head with cam holders?
