burt
    94
    cambs
1666 profile views
burt's Achievements
  1. Not really, still no power at the plug
  2. Thanks for that might be a big help. I didn't find any power in the plug
  3. still can't find anything Loose. Tried a different heater control that doesn't work. Does anybody know if the plug that goes into the heater has a live and which wire because I couldn't find a live with ignition on
  4. Heater fan didn't work on the way to work yesterday, but briefly did on way downhill on way home! I've got lots of the dash pulled apart now. Checked the visible connections. Can't find any loose.
  5. No its only started happening in the past few days since I been back at work. No chance to do more than check fuses (easy bits) Everything else works in car works
  6. Fully cutting out on any speed
  7. I've had a search but can't find this problem Heater control panel works on every position, heats well and every speed works. Problem is it cuts out when I accelerate! I've checked all the fuses and can't find anything wrong with them. I'm thinking it's a loose wire but has anybody got any other ideas of what it could be, or where/what I can check Cars a 97 n/a Thanks Burt
  8. Found the bulbs in my eBay list. I ordered t3 and they fit
  9. Think it's t3. 8mm base
  10. Not a T5/286, They are like a thinner smaller 501/t10 T5 are used in fag lighter, 2 in heater and depending on the dials used dials there's some there and some I have a pack of led lights to use in switches but there's no part number
  11. http://www.pit-bitz.com/product_info.php/spice-toyota-starlett-ep91-p-793
  12. Hope it helps.
  13. Mine all came out of the sr I scrapped
  14. Installing sr doors onto a na (the way I did it) both models were 1997 Unbolt wings from the car Unbolt doors Drill hole in A pillar for cable to pass through There is a recessed section on the pillar so very obvious (should really paint the edge) Line up new door and bolt on Push loom plug through the new hole and plug into the matching plug in car behind the kick panel Bolt wings back on MAKING THE CENTRAL LOCKING WORK. Remove trim panel/speaker from under steering wheel Locate this plug/fuse the white one on the right Add this relay to it Check central locking works MAKING THE WINDOWS WORK. With the dials out find this orange plug Fit this module Install here, if you have taken the module from a sr it will probably have the bracket attached Check windows work before putting dials back in. The whole job was straight forward and was finished in a day. If you are switching doors like I did, don't forget to change the locks over from the old doors or you will have 2 keys. I also put a remote central locking kit at the same time Burt
  15. I made a guide my na has sr doors on.I'll try to find it
