Nilz90
  • Content Count
    185
Everything posted by Nilz90
  1. Hi guys, I have a starlet gt with a TD04 turbo. I had my timing done recently and my mechanic said it was way off and he wasn't sure why. His set it to normal now but I feel like I lost power slightly top end. Seems like the accelerator struggles to pick up now slightly. Haven't tested the car fully with increased boost as it's always been set to 0.3 when I brought the project and haven't got round to connecting my boost controller up. Is this set up right or it should the timing be more advance for a TD04?
  2. Hi bud, I don't think they are in good condition was told they need replacing. I can take pics when I replace them. How much are you after for yours?
  3. Hi, I'm after the right hand side poly bush engine mount and the left hand side engine/gearbox mount. Let me know if any one has them for sale. Thanks
  4. Wanted Drivers Side Poly Bush Engine Mount. Let me know if anyone has one for sale.
  5. Ok thanks I will connect it up. Will it be ok to run it on 0.8 bar with Standard fueling. I don't have a FPR or FCD installed, just a walbaro fuel pump?
  6. Hi guys, I have a starlet gt on a TD04 with a Kinguwa actuator, when I brought the car the boost was set at 0.4. It came with a boost controller but the engine pipes for the boost controller were disconnected. I want to raise the boost level to 0.7. What's the best way to do this? I'm happy to leave the controller disconnected until I map the car sometime next year or would I be better off connecting it up for now?
  7. As per title, let me know if you have a poly bush engine mount for sale? Thanks N
  8. Hi, My starlet GT has no lights on the heater controls. Does anyone know what size bulbs they are unless they were made with no lights? Thanks
  9. Nilz90
    Oil Leak
    Cheers buddy
  10. Nilz90
    Oil Leak
    I'm just about to order the parts in. Can someone confirm that these are the two seals mentioned above I need please http://www.tuningdevelopments.co.uk/product_info.php?products_id=552 http://www.tuningdevelopments.co.uk/product_info.php?products_id=2374
  11. Nilz90
    Oil Leak
    Does anyone know how much roughly this job would cost for a garage? I spoke to one garsge snd he said engine might need to come out if its the oil pump?
  12. Nilz90
    Oil Leak
    Cheers guys for your help, would I also be better off doing the waterpump while i'm there too? I brought the car which came with no history n apparently the engine was rebuilt 300 miles ago, not sure what sort of job they done if its leaking already so I'm thinking i'll be better off doing all of the above while i'm there.
  13. Nilz90
    Oil Leak
    Hi I brought the car with it leaking oil, I was wondering if anyone would know what the silver piece is in the below pic where the oil is leaking from? https://ibb.co/gOuEx5
  14. Are JAM Racing ECU's any good seen some for sale for around 400 or would it be better to stick to Emb?
  15. Yep I take that as a no then lol
  16. Does anyone know if the tuning developments Fpr is good?
  17. Hi, Can anyone recommend me any good adjustable fuel pressure regulators, looking for a new one under 100? Don't know much about them. Cheers
  18. I've decided to go for the emange blue ecu. So am I right in thinking the only additional things i need is: Wideband afr gauge Fuel cut defender - do i need this? Fuel pressure regulator And maybe bigger injectors
  19. I'm happy with anything between 190 to 210 bhp not looking to push the TD04 to the limits or anything.
  20. Hi, Does anyone know the size of the original bonnet bolts for the gt or where I can get them from? I brought the car with bonnet spacers but not a fan of them. Thanks
  21. Not thought about bigger injectors yet so do you think I'll be ok running the car how it is on no map?
  22. Hi All, I recently brought a Starlet GT which is nearly ready now. It has a TD04 kit, FMIC and a full decat system. I was wondering what are the options to tune the car so it is fueling and running correctly. I know there's a few different ECU's but is there a specialist to get the car tuned without changing the ECU?
  23. Thanks mate this is really helpful much appreciated. I think I'll go for the first option would be much tidier.
  24. Sorry mate didn't realise. Try the below link https://ibb.co/nDjT7v
  25. Here's a pic of the engine bay it has a td04 set up. http://i892.photobucket.com/albums/ac122/n1lz/IMG_3855_1.jpg
