Tomson
    57
About Tomson
  • Birthday 02/25/1991
    Finland
    Jdm
1598 profile views
Tomson's Achievements
  1. Have someone rebuild the rear brake calibers? I need to do my own and just ordered the sealings etc to make it work with the old pistons.. give some advices if you guys have!
  2. well lets keep updating even if there is nobody reading this^^ someone have a idea where to buy distributor cap and rotor arm?
  3. Paint problems fixed (hood+front bumper)
  4. Well its been months from the last visit, but nothing special have happened, just driving! and really enjoying it. I have done just some minor things like installing the outside temperature meter, better lights/bulbs and so on. Actually have driven over 30,000km in the past one year so not bad at all! Everything works fine, no problems at all, not even starting problems when there is -25 C outside, car starts like there would be a summer time So only maintenance things to do before spring arrive, then im going to paint my hood and front bumper again and starting to look for new summer rims also.
  5. So, my remote key dont have any battery inside.. what is the correct type for Glanza (-97)? CR2016 or CR2032 or something else maybe?
  6. Yep! also trying to get better light output to my low beams with leds or something.. the halogens are just so bad.
  7. Well the blueprint one did fitted, just saying this if someone else want to know in future.
  8. This time of the year....
  9. Lets get back to this topic, someone used that blueprint filter? readed somewhere, that the inlet is bigger than the standard one? can someone combine to this? I got filter change after 2weeks so its time to order a new filter if that blueprint is not going to fit (the part numbers were exact the same..)
  10. Love those seats !
  11. Clean looking glanza !
  12. Up, still looking
  13. And now when the transmission is working again, i finished my exhaust by changing the both mufflers, flex pipe and the gaskets from connections. (and the tip is little bit "more like it" now).
  14. Some updates. Car is up and running again! changes the bearings and syncros from the transmission, and now its working really smoothly again! 2. Gear syncro, new 2. Gear syncro, old one.. you can see the difference. And this was the bearing where to noise came from.
