ashford_ep91
    21
    Ashford, Kent
1118 profile views
ashford_ep91's Achievements
  1. Trying to eliminate a gear change issue before I remove the gearbox. Any about?
  2. Also got an issue of 1st gear 'grabbing' (wont come out of 1st) and 2nd sometimes hard to engage. Thinking potential clutch drag as I'm getting a grind in reverse occasionally. I've changed the clutch slave due to leaking, master seems dry but I've not pulled back the dust boot. sugercube seems OK, and I've fitted solid gearchange bushes (ID Workz bearing type). i did have a Hypersports quickshift fitted, removed it and changed was improved.
  3. Been fitted for a while, but the box was recently rebuilt, I’ll have to check if it had new diff bearings. Tracking feels spot on, but I’ve corner weight and alignment equipment at work so that’s my first step.
  4. Not sure if I should suffer from it or not? Diff feels great on roundabouts etc, can really feel it working, but trying to put down 235bhp is bit of a task in 2nd and 3rd. Wheel can pull about it I’m not holding on! I thought it was just a side effect of having that power, but it seems Facebook disagrees. If I shouldn’t, can TRD still supply diff plates, or should I be looking at Kazz/Quaife?
  5. Bump, still after this lot! Got a space saver, still need 96 spec rear bench, or complete 98 spec interior.
  6. None of my controls on the heater panel light up, only the AC switch does. What bulbs are required?
  7. I’m not happy with the Yellowstuff in my V. I’ve seen old posts of people running M1144, but can’t see any available now. Are the calipers the same as anything else?
  8. I can get spigot rings in the correct size, 60.1mm for the Clio. The 172 calipers are 2 piece, the Brembo are a single piece 4 pot. Once I’ve measured up and they look like they’ll fit, I’ll speak to the maker of the Clio adapters.
  9. I'll have a measure up at the weekend and see what it'll take. I'll also offer up some 172 calipers and see how they look, the Clio runs 280mm discs so might work. The centre bore is slightly larger on the Clio disc, so I can offer one up as a trial fit.
  10. I only ask as I come from the Renault scene prior to me getting a Glanza. Many people fit the Brembo calipers from the Clio 197/200 onto the 172/182, and can be fitted behind 15" wheels. I happen to have both a set of calipers, and a set of the wheels in the photo. I'm taking my wheels off this weekend, so I'll have an offer up, and see how things look. These calipers can be had for as little as £100 a pair, so might be a nice alternative to other options.
  11. Finally got JTs Glanza at the weekend. My god its good to drive! Only issue I have is 2nd, and occasionally 1st can be tight to select. All other gears are ok. I can drive around it, but my wife isnt finding it so easy. Ive read about a bush on the selector linkage at the gearbox end - anyone have a picture of this? Can the linkages be adjusted side to side? Cheers.
  12. Apexi is Japanese. Does it have a date stamp on it?
  13. If not, Im guessing they can be swapped? Took some persuading to get the wife to let me sell our perfectly good car to get a Glanza, and I dont need any agg!
  14. Would you be able to post the wiper motor and arm?
  15. As above - collecting car tomorrow and it has no rear wiper, something I hate not having! Need both motor and arm. The car I'm getting is white, with a black bonnet. Is anyone in the South East interested in a swap? It's not really for me, but I understand some people like the look. Its recently been painted, so is in top condition. I'm happy to travel, and do the work to swap them over.
