mcleod
Member-
73 -
Everything posted by mcleod
correct me if im wrong but it means a higher sidewall thus giveing more flex when turning
good job mate. how did you do all that damage?
where did the people who have rear trailing arm poly bushes get them from???? they say toytuning but ive checked and can't find them
put me down
top bloke picked up my ali rad at pretty short notice which he was happy with.
ultra racing 4 point lower arm will make a massive difference
i will prob be at the next one i saw that black glanza with white wheels today in walmsley where the road works are.
stunning mate
would the light not show thru better if the old dials are removed?
they look fantastic and great guide i may be buying these sometime soon
edited enjoy peeps
well done mate and that is seriously lucky gettting an interview thew same day lol
How Much Money Are People Spending On There Glanza V And Starlets
mcleod replied to l1 jev's topic in Lifestyle General
about 15k including the car maybe more lol -
hi can you get manifold/head studs and nuts? i only need one but will take them however they come
erm in that case mate im not sure lol
i'll get more pics when its sunny. and piston ring gaps as in piston size???? if so there 74.5mm. if not then i dont know mate. the new mani will be unveiled soon enough. and so will the rocker cover when its on my forged engine
cheers lads. and the rear diffuser is a custom job off a company on ebay who make lotus and vx220 ones.
SPEC AS IT IS NOW. ENGINE Section Engine Damper to go on 550cc Injectors NGK Plugs Iridium Ross Forged Pistons Pauter Rods Cruise Valve Springs NST Crank Pully ACL Bearings Fully race balanced Engine work Service cylinder head Replace all valve guides Service and replace (as necc) valves,lap and vacuum test. Surface grind head face 0.005" Strip,prepare,wash and rebuild with new stem seals and springs Short motor assembly Rebore to pistons supplied Surface grind block face by 0.005",polish crankshaft, race balance to crankshaft/flywheel/clutch/connecting rods and pistons gap piston rings to rrr turbo specification prepare, wash and rebuild Fit front cover and rear oil pump (supplied) Acl main bearings Acl b/e bearings Acl thrust washers* brand new ihi vf34 turbo heat painted wepr td04 mani with external wastegate plumbed back to decat double heat wrapped decat front mounted greddy oil cooler and relocation kit (to go on) Emanage ultimate turbosmart external wastegate custom meshed front mounted funnel custom intercooler kit reflective wrapped 2x spal slimline fans 1 suck 1 blow Hks ssqv 2 Sard cooling plate (for sale soon) Koyo Ali rad (to go on) custom catch can Japspeed stainless exhaust system double wrapped in thermotec copper wrap Ngk grade 7 plugs Magnecore 8.5mm leads sard header tank (to go on) sard thermostat Blitz dsbc type r boost controller (just got it back so it needs setting up soon) NICK!!! lol Manual boost controller (temporary until ebc is returned) Set to 0.98 bar speedo converter straight cut gearbox and aftermarket diff fidanza lightweight flywheel exedy paddle clutch SUSPENSION AND CHASSIS Tein flex coilovers 3G/Wilwood 280mm big brake kit Full roll cage with carbon crumple bars Whiteline Front anti roll bar 24mm Whiteline Rear anti roll bar Whiteline anti lift kit RSR panhard rod Ultra racing front 4 point lower arm bar Ultra racing rear lower arm bar Zep c pillar bar Zep 3 point rear strut brace Zep cross bars tanbe front strut brace 15" Rota jmags wrapped in yokohama parada spec 2s poly bushes in new lower arms trd engine mounts fully aligned and set up to 2 deg neg camber on front INTERIOR Recaro sport seats (out of an evo 7) semi stripped rear Luke 4 point harnesses Momo steering wheel (advance edition) Razo aluminium gearknob Triple A pillar pod Double dash pod Stack AFR gauge Stack boost gauge in bar Stack oil pressure gauge Stack oil temp gauge Stack water temp gauge Clarion cd/mp3 player with hard drive 4" Kicker components Kicker kx75 2 channel amp Jbl GT 2 channel amp 12" KIcker sub Custom boot build Harmon Kardon Ipod connectivity adapter EXTERIOR Custom rear bumper to make a euro plate fit and also smoothed the slats in each side for a more unique look. Cut out and smoothed front bumper so no restrictions are in place of the fmic. Also the whole bottom half of the car has been sprayed a newer and more unique grey colour. Jam reverse scoop Toms grill (strengthened) Front carbon splitter custom rear diffuser WHAT I PLAN ON DOING is making the ultimate handling and powered starlet around well i bought my advance in january 07 and ive been through some rough times of wanting to get rid but ive chose to keep her now and ive ordered some 21st bday prezis for myself so here goes. i bought her with gold volk te37s, apexi exhaust, trd shortshift, tein coilovers,rsr panhard rod and hks air filter. The first thing i bought was a hks recirculating dump valve off an evo 6, not ideal but it does the job i'll be replacing that soon. i then started on the handling so i bought a whiteline antilift kit and front and rear arb off toby on the group buy he did. The next thing on the list was brakes after alot of debating i found the 3g and wilwood combination off dave so i got in on that group buy about 4 months later they arrived and what a piece of kit that was. while daves brake group buy was on i came across a blitz access ecu on ebay so i went for it and what a difference that made i was well impressed with it. one day when i was driving to work i bounced over a unavoidable rock and i dented two of my four wheels (wounded) so i purchased a set of 15'' jmags off dave (marmite wheels. lol) BEFORE AFTER After that toby started a ultra racing group buy so i put my name down for the 4 point front lower arm and the 2 point rear lower arm bars. just a few pics of my handling parts that are on. wilwood/3g 4 pots off dave burwash whiteline 24mm front arb, ultra racing 4 point lower arm bar, and whiteline anti lift kit tein coilovers, rsr panhard rod and whiteline rear arb While i was waiting for these to arrive i decided to sell the ecu as i was going to need a emanage for the setup i was going for so i sold it for what i paid for it so it was worth the wait. Then it was coming closer to my 21st bday so my other half wanted to know what i wanted for my bday and i thought why not get a number plate so i found the one i wanted and went for it only to find one problem, it only looked right in a line and i coudn't pull myself to get it on a square plate, so to skill customs in marple i went and my car underwent the sides being painted grey again, arches rolled and the rear bumper modified. well i got my car back this week ending in 17th/03/08. so thats the score upto now i'll update soon with pics etc. hope its up to scratch and ididn't pass my engilish gcse if you can tell lol. to come guys and gals speedvision hybrid, autobahn fmic, hks ssqv, blitz dual solenoid ebc,and much more. plus i treated myself to a 8megapixel camera so expect alot more pics lol. i went playing football on sunday the 20/4/08 and sprained my ankle lol so ive not been in work for mon and tues and maybe weds but we'l see. But my dremel arrived so ive finished off my front bumper for now but i'll show pics when its on the car. and also i fitted a sard cooling block after some modding lol here it is it has my pressure sensor and temp sensor plumbed in so i only need to wire them and im done. i discovered this in my back box not so long ago lol i mite just go to powerflow sometime soon and get a full system made up. and a few pics of the front mount finally fitted and running ive not put my plate on yet as it fell off so its gonna be above the right fog light as your looking at the pic. and its a short rectangle plate so it looks ok the gearknob is off a rx7 so i retaped the thread to fit the gt's getting mapped by tuning developments tomorrow (today being 30/05/08) so i'll have another update and a proper spec hopefully. Quite an update today. wednesday the17th september i recieved my jam reverse scoop off ramsey so i sent that to the paint shop and i got that back on friday the 19th. and then with all this stripping of cars going on i've been hunting for a bargain. so when i saw ben-j' stripping his track slag i thought it was christmas. so i first started off with just wanting the header tank, catch can, and low temp thermostat. and then i thought why dont i just buy the gearbox and lsd. but seen as only the back half of a cage is 550 from rhdjapan. heres a lil pic of my recaros finally fitted i just thought sack it i'll get the cage instead lol. so im now a cage owner lol. i'll put pics up soon as i only have the back half in as the front interferes with my gauges. anyway i picked all this stuff up today on the 21st september just for record. front of the cage is now in along with my roll pods oh yeah and i only have one piece of the jigsaw to complete the puzzle heres what shes running at too 183.6bhp at 0.98 bar 8/11/08 a very big order of parts will be going in on the following wedsneday. including the final part to the jigsaw plus the last of my many handling parts. just ordered exedy paddle clutch, braided clutch line, speedo converter, cruise valve springs, fidanza lightweight flywheel, trd bush set no1 and 2 lower arm and trd twist beam bushes, toytuning uprated engine mount set. most of my parts have arrived for now. finally got my hands on a toms grill but i had a bit of bad luck in a uninsured postage. and heres the finished product i'll fit it tomorrow and put some pics up turbo shat itself last night lol 24/12 im on the look out for a forged engine, emanage ultimate, and a massive turbo. oh yeah and a big pot of gold would help too who wants to help me choose the turbo???? pm me with decisions ordered some copper exhaust wrap, oil catch can, heat reflective tape and some mocal oil cooler brackets for the future as i intend on getting a 13 row mocal cooler with lines, thermostat,and temp and pressure housings. 8/1/09 brand new lower arms have arrived just need to figure out how to remove the brand new oem bushes so i can fit my trd ones. 10/01/09 just picked up my straight cut gearbox with aftermarket lsd in it. from ben-j 13/01/09 all seems to be falling in place now. might be finished sooner than i think. ive just ordered some more handling additions, and the final piece of my jigsaw . also a forged engine is in nearly reaching ditance. 16/01/09 ive been on a mass spending spree in the past few days japspeed exhaust turned up today so just waiting on some more copper wrap so i can double wrap it. ordered my turbo today too, aswell as a turbosmart wastegate, turbosmart oil cap, ali rad, mani and downpipe. and about 3 things which i can't unveil yet. one of which i'll update you on the 17th. 17/01/09 been at gees all day removing his forged engine which is now mine also picked up his engine damper, and 550 injectors too so this is where it starts. 19/01/09 dropped engine off at tuning developments yesterday and wrapped most of my japspeed exhaust in copper thermotec heat wrap. im just waiting on another roll so i can double wrap it 24/01/09 well fitted my exhaust today after it had been double copper wrapped etc 27/01/09 a lil sneak peek at a future mod and also this turned up today to the quality is excellent 4/2/09 not much of an update due to waiting on parts etc but an update none the less. just picked these up from rs electroplating they even did all the little bolts that held everything together. but they could get the throttle sensor off the throttle body so when i do then i'll take it back and get it sorted. 10/02/09 just picked this ball bearing mo fo up 16/02/09 this turned up today 23/02/09 just got the final piece to the zep jigsaw and had to cut my diffuser down because i measured it with my old apexi backbox which is tiny to the japspeed ones and then i fitted it Thought i'd give an update well the engines in now as well as practically most things i have bar a few its mapped to 1.3 bar just wants tweaking to 1.4 soon but it is savage im scared even walking past it on my drive but im back in love with it. heres a few pics forged engine finally fitted and all good 07/09/09 hey people not updated in a while just got these and got this a while back at a good price the cars goin to tuning developmetns this weekend to fit sard breather tank greddy oil cooler and relocation kit cams ali rad spark plugs fuel filter longer hub studs and fix a few oil leaks and mapped to 1.5 bar then all i'll be needing is a custom fuel rail and braided lines fse adjustable fpr and some tyres for november. dont think i'll be going for semi slicks though as its in november and no doubt it'll be moist progress at tuning developments HQ had to get some greddy gauges so the sensors fit into the oil cooler kit __________________ __________________ POWER IS NOTHING-WITHOUT NOISE. (FACT)
ive got hemroids if that helps???????????????
caraudiosecurity.com mate its cheap. and alpine or clarion are the best clarion do one with a hard drive like the one i have but alpine are by far the best sounding head unit
M60 EOD = MCL EOD M60 EOD
i think GAY is a piss poor way to word your opinion!
dya know on a ep82? the reg plate is on the bumper and only wide enough for the jap square plate i want the gap widening so a long plate will fit and then filled in at the bottom so it looks ok.
do they have a website
